Results 11 to 13 of 13
Thread: Sodium hypochlorite and PH levels
    Default Re: Sodium hypochlorite and PH levels
    Ah, Grasshopper! Very astute question!
    Chlorine itself in the water is VERY acidic. Gas chlorination (don't try this at home) can drive pH through the floor!
    The acidity of the chlorine in the water and alkalinity of the bleach neutralize each other! So it has zero impact on pH!
    Aeration has to do with getting the CO2 out of the water... a little like making soda flat when it loses it...CARBONATION!
    (ah the Great Circle of Life for us poolowners! )
    Jun 2011
    Louisville KY
    Quote Originally Posted by CarlD View Post
    Thanks again Carl for a very easy to understand explanation.
    Probably the nth time you’ve done that.
    Circa 1980 IG, VL, 36K Gal, DE, Chlorine
    That's me!
    Simple.....
