Results 1 to 10 of 84
Thread: Time to replace sand?
    Default Re: Time to replace sand?
    Ben's response was to stick with the 6 gallon bleach doseage that he initially recommended. With large amounts of ammonia to break down, you're going to have higher than normal combined chlorine to deal with, that can be very irritating and uncomfortable. So..his recommendation was to break it down slowly with the lower doses of bleach, until you start getting CC readings of 1 or 2--at which time you can up the doseage and go ahead and get rid of it. So...stick with the 6 gallon dose for now.
    I agree with Watermom on the foaming--it's likely evidence of the algaecide breaking down. Stay the course the way Ben recommended--and we'll help you get it cleaned up!!
    jonno is offline Subscriber Thread Analyst jonno 0
    Jun 2011
    Brookeville, MD
    Roger that and thanks! I'll stay the course and keep posting my numbers.
    Taylor K-2006, IG Vinyl 26,000g, Sand filter 275 lbs, 3/4 HP Hayward Super Pump II, CYA over 100, Using 12.5% bleach
    18'x36' rectangle 26K gal IG pool; Liquid Chlorine 12.5% ; Sand Filter 275 lbs. sand filter; Hayward Super Pump II 3/4 HP pump; 23 hrshrs; Taylor K-2006; delivered via truck; summer: ; winter: ; iPad; PF:4.6
    Jun 2011
    Brookeville, MD
    Evening report:
    FC 2.3
    CC 0.4 (tested twice to confirm both FC and CC)
    pH 7.2 / 7.4
    TA 190
    After pulling the water sample, I added 1 pint acid, brushed the walls and bottom. Visibility unchanged over past two days (about 2'), then added 6 gallons of bleach. Still have scattering of light foam on the surface.
    Since the CC was 0.4, I should up the bleach according to your post earlier today. How much?
    Do you have any guess at the timeframe until this treatment clears the water up - days weeks?
    I have questions about maintaining the pool with CYA so high (somewhere way over 100), but I'll wait until I get to that point before asking. Thanks!
    Jun 2011
    Brookeville, MD
    Disregard yesterday evening's water tests! I messed up. Here are the morning numbers:
    FC 0.5
    CC 3.5
    pH 7.2 / 7.4
    TA 180
    Since the pH is still up, even after last nitght's pint, I'll add another pint of acid this morning. No change in visibility. Still have scattering of light foam on the surface. Water is starting to look more green than blue - could it be another algae bloom?
    Remember to approach adding chemicals conservatively. Usually, bleach/chlorine is the exception but given your unusual circumstance even that should be done with care. Your FC is down so you need to raise it to the level Ben recommends.
    Jun 2011
    Brookeville, MD
    Thanks Carl. Ben's chart shows that given my CYA of 100 to 200, my FC level should be 8 to 15 ppm). However, I have a lot of ammonia so Ben gave me a treatment plan to follow until the CC is down to 1 or 2. The interim plan is to add 6 gallons of bleach every evening, add a pint of muratic acid when the pH creeps above 7.0, and keep aerating.
    Jun 2011
    Brookeville, MD
    Evening numbers - pool color is changing from blue to yellow green!
    FC 0.0
    CC 3.0
    pH 7.2
    TA 180
    I added another pint of acid this morning and will get some more tomorrow to keep the pH low, but today the color of the water no longer has any blue coloration and is more lemon lime. Visibility is still only 20-24 inches. This is nerve-racking. I really don't want to replace the water. Ben, Janet, Watermom - is there anything else I should be doing?
    Jun 2011
    Brookeville, MD
    Here is a photo of my pool taken this morning. This is the BEFORE photo.
    I've spent the past two weeks working to eliminate the excess ammonia and lower the TA - this was not a process where progress is visible.
    Now that Ben has increased the evening dosage of bleach to shock levels (considering my high CYA), there should be some visible progress as the algae and visibility problems resolve.
    I'll post an AFTER photo as soon as everything is balanced and clear. This is day 33 since opening the pool - wish I'd never gone to the pool store...
