Re: Time to replace sand?
Here is a photo of my pool taken this morning. This is the BEFORE photo.
I've spent the past two weeks working to eliminate the excess ammonia and lower the TA - this was not a process where progress is visible.
Now that Ben has increased the evening dosage of bleach to shock levels (considering my high CYA), there should be some visible progress as the algae and visibility problems resolve.
I'll post an AFTER photo as soon as everything is balanced and clear. This is day 33 since opening the pool - wish I'd never gone to the pool store...
Taylor K-2006, IG Vinyl 26,000g, Sand filter 275 lbs, 3/4 HP Hayward Super Pump II, CYA over 100, Using 12.5% bleach
18'x36' rectangle 26K gal IG pool; Liquid Chlorine 12.5% ; Sand Filter 275 lbs. sand filter; Hayward Super Pump II 3/4 HP pump; 23 hrshrs; Taylor K-2006; delivered via truck; summer: ; winter: ; iPad; PF:4.6
