Results 1 to 10 of 84
Thread: Time to replace sand?
    jonno is offline Subscriber Thread Analyst jonno 0
    Jun 2011
    Brookeville, MD
    Default Re: Time to replace sand?
    Thanks Carl. I put a little DE in the skimmer and installed a skimmer sock. Looking even better than this morning.
    7pm Test Results are:
    FC 25.5
    CC 1.5
    pH 7.5
    TA 180
    CYA - black dot disappears well before the 100 mark.
    pH and TA numbers may be off due to high FC ppm.
    Taylor K-2006, IG Vinyl 26,000g, Sand filter 275 lbs, 3/4 HP Hayward Super Pump II, CYA over 100, Using 12.5% bleach
    18'x36' rectangle 26K gal IG pool; Liquid Chlorine 12.5% ; Sand Filter 275 lbs. sand filter; Hayward Super Pump II 3/4 HP pump; 23 hrshrs; Taylor K-2006; delivered via truck; summer: ; winter: ; iPad; PF:4.6
    Jun 2011
    Brookeville, MD
    Carl, Watermom, Janet, or Ben -
    I have a question about the timing of taking an end-of-day FC test and when to take it the next morning. To end the shock phase, I know I want a FC that loses no more than 1ppm overnight, but when does "overnight" start and end? From reading other posts, I thought the last test of the day can be taken whenever the sun is off the pool and the first test the next morning is to be within two hours of sunrise.
    This evening, I did a test at 7pm and the FC was 25.5. I thought that was late enough to be my final test. Out of curiousity, I tested again 3 hours later at 10pm and was surprised that the FC dropped 4ppm (from 25.5 to 21.5). I added almost a gallon of bleach to bring it back to 25ppm, but this got me wondering.
    Here're my questions:
    • Why did the FC drop so much between 7p and 10p?
    • Is it because the FC is still fighting nasties in the water? The CC at 10p was 1.5, so I think this also is a clue that the shock level of bleach is still needed.
    • The sun didn't actually set until 8:38p tonight - could the UV rays hitting the pool indirectly between 7p and 8:38p also have contributed to the drop in FC?
    • The water is so invitingly clear, how many more days should I be prepared to continue frequent testing and keeping the FC at shock level (i.e., 25ppm)?
    Sorry to be hounding you with so many questions - I'm curious about the chemistry and I've also got several eager swimmers attracted to the sparkling water.
    Jun 2011
    Brookeville, MD
    6:40a FC 23.0 and CC 1.0 - will continue testing and topping to 25ppm today.
    Quote Originally Posted by jonno View Post
    This is correct.
    • [1]Why did the FC drop so much between 7p and 10p?
      [2]Is it because the FC is still fighting nasties in the water? The CC at 10p was 1.5, so I think this also is a clue that the shock level of bleach is still needed.
      [3]The sun didn't actually set until 8:38p tonight - could the UV rays hitting the pool indirectly between 7p and 8:38p also have contributed to the drop in FC?
      [4]The water is so invitingly clear, how many more days should I be prepared to continue frequent testing and keeping the FC at shock level (i.e., 25ppm)?
    1. Your statement in #2 answers it.
    2. Yes.
    3. I don't know. I wouldn't think the sun at that late hour would be strong enough to cause much chlorine loss, but why don't you wait a little later tomorrow evening before testing.
    4. Hopefully not too much longer. Keep your fingers crossed for sometime this weekend.
    Don't worry about all the questions. That is why we are here. Sorry none of us replied to this yesterday. It has been pretty busy around here lately and believe it or not, we all have lives outside this forum!
    Jun 2011
    Brookeville, MD
    Thanks Watermom. I'll try to test around 8. Last night I had to test at 6:30p and this morning at 7a the FC was 23.5ppm (CC barely 1.0) - that's the smallest overnight drop so far. I'll keep testing during the day. I'm almost out of the R-0871 titrating reagent - a 2oz bottle used up in less than a week. But testing 5 or 6 times a day and using 50+ drops every test consumes a lot. I had already ordered more, but then I found that Amato industries is closer to my house than the pool store (they have two locations, here in MD and in northern VA - how lucky is that! The woman there is very nice and I can pick some more up today. I'll keep my fingers crossed that the FC will start to hold steady.
    By the way, the skimmer sock really makes a difference! Every morning and evening for the past days, I've taken it off and swished it around in a bucket of water to clean it off - not only does it leave the bucket water full of tiny insects and bits, but it turns the water very cloudy - so the sock is trapping tiny stuff too. I don't ever remember the water looking this clear!
    I am a happy convert to BBB!
    Jun 2011
    In the Sticks near Houston, TX
    Maybe I missed it, but what exactly is a skimmer sock? Thanks in advance.
    @ Goose
    Skimmer Socks at Amazon
    @ Jonno, others
    Coral Chemical's Green to Clean is just ammonia!
    Instead of ""Disodiumsalt of ethylenediaminetetraaceticaciddihydratediammoniums ulfate", which is Fred Luth's attempt to obfuscate what he's selling, the chemicals should be listed as
    Ethylenediaminetetraacetic acid (EDTA) ?%
    Ammonium sulfate ?%
    OR
    Ammonium sulfate EDTA 100%
    Regardliess, it's mostly ammonium sulfate, which is an industrial waste product that I have bought in 100# bags for about $10 a bag! (I do think they are using a somewhat purified version, that may cost more than $10 cwt.)
    Coral Chemials -- used to be Coral Seas -- is a one product company, like United Chemical. But where United Chemical sells sodium bromide, mixed a bunch of different ways, Coral sells ammonia, blended 2 ways: "Green to Clean" and "Yellow Out". I encountered Fred Luth at an NSPI trade show years ago, and thought he was going to jump down my throat when I asked him if "Yellow OUT" was just ammonia.
    Jun 2011
    Brookeville, MD
    The pool looks great! But I'm still in a shock cycle. Went swimming today for the first time this season - it made me remember that the pool is not just a big science project. It. was. wonderful!
    As of 8pm:
    FC 25.5
    CC 1.0
    pH 7.4 (added 1 qt m. acid)
    TA 180
    I'm hoping that one of these nights the FC will hold. POPP.
    Jun 2011
    Brookeville, MD
    I couldn't test within 2 hours of sunrise because we had a major storm - almost an inch of rain (desparately needed).
    9am numbers:
    FC 21 (-4.5 drop over 13 overnight hours - could some of this be dilution from the rain water?)
    CC 0.5 (yay!)
    pH 7.2 - Since the FC is higher than 15, this is falsely high, so I'm hesitant to add any more m. acid until I can lower the FC below 15.
    TA 170 - Probably not a good reading due to high FC - it turned from green to blue at 140, light orange at 160, orangey-reddish at 170
    More storms and rain today, but I'll keep topping off the chlorine level to 25 throughout and see how the FC holds tonight.
    My pool is an unbelievable transformation - thanks to Ben, forum moderators, and the community. Ben - Have you considered starting an area for posts of appreciation and success stories? Perhaps under the group Ben's Corner, Water Treatment Testing and Problems, or even Odds and Ends. Such an area would be encouragement for people with big problems to know that the POPP is worth it. My path from swamp to crystal clear water covers eight pages of posts - but if there were a Success StoryArea, I would condense it to a single post with a few before and after photos and put in a link to this thread for anyone who wants details.
  1. Time to replace the cell?
    By semenzato in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-24-2011, 03:26 AM
  2. How often shoud I replace sand in sand filter?
    By mikef in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 11:41 PM
  3. Time to replace the QuikChlor...
    By steveinaz in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-20-2011, 11:44 AM
  4. Time to replace my liner?
    By mdenegre in forum In-Ground Pool Construction and Repair
    Last Post: 11-14-2010, 10:39 AM
  5. Time to replace the Dolphin Dynamic
    By beantown in forum Pool Cleaning: Manual or Automatic
    Last Post: 09-09-2010, 09:28 PM
