I for one picked the Autopilot because it seemed a slightly safer bet. I installed it myself and didn't have to worry about flow thanks to the bypass valve (too much flow is not ideal for the generator, probably because it prevents the "instantaneous shocking" that gets rid of chlorine residuals---there may be other reasons). I also like the temperature compensation, and the fact that the unit works with an external timer, or it can use its own timer, to control itself as well as a one or two-speed pump. (Some of these features may be available on the Aquarite, I can't remember). The price difference is not substantial, once you include installation cost. It took me about 5 hours to install, but I fixed a few extra kludges in the boiler/pool equipment room while I was at it (rerouted ugly copper tubing, cleaned up electrical stuff, etc.)
Luigi
Reason: typo
