Answering just for the Pool Pilot, you do not want to interface the unit to communicate through the electronic control system as you will lose some of the key features of the Pool Pilot Digital. Specifically, Automatic Temperature Compensation and Salt amount display. What this means to you is that you will need to be as diligent in adjusting the Purifier % setting when temperatures change (the Pool Pilot does this for you).
The Pool Pilot too, will have to be mounted as a separate system, as you mentioned the Intellichlor would need to be.
This would be the same for anyone elses system, unless you go back with the replacment components from Goldline.
