Thread: No change in CYA
    Jun 2011
    Southwest Arkansas
    Cool No change in CYA
    I have been a lurker for sometime but I need help with my CYA.
    19,000 Gallons ABG Vinyl Pool
    Sand Filter 1.5 hp pump (I think)
    Opened the pool to a green swamp but thanks to the BBB method the pool is crystal clear only a week later.
    Current test with Taylor K-2006
    FC 17 ppm
    PH 7.6
    TA 100 ppm
    CH 90 ppm
    CYA 0
    I have put 4lbs of stablizer over the last week by hanging a sock in the path of the return. I still do not see any change in the CYA. I have another 4lbs that I can continue to add over the next week but I am worried that it will get to high over time. So what should I do now?
    Thanks for this forum. My husband is now a BBB believer! Loving the clear pool I just want to keep it that way.
    Default Re: No change in CYA
    You probably are just between 25-30ppm which is hard to distinguish on the test. Go ahead and add 2 more pounds. A week later, test again. That should put you right around 40 which would be a good level.
    Jun 2011
    Southwest Arkansas
    Thank you for the information.
