Results 11 to 17 of 17
Thread: need to cover my pool for 6 weeks while i am away...help with chemical suggestions
    Aug 2010
    Default Re: need to cover my pool for 6 weeks while i am away...help with chemical suggestion
    putting the pump on a timer is not an option.
    You can name chemicals here -- you just can't try to sell other people on them. We name chemicals and brands all the time . . . like 20 Mule Team borax ;-)
    Ben
    PS. I'm curious what company claims they have a "90 day algaecide", anyhow.
    Aug 2010
    Total Algaecide by Doheny's Water wearhouse. Destroys Resistant Algae, Extra-strength Formula, Prevents New Algae Growth for 90 Days, Non-foaming. It was recommended to me. I will certainly give it a try. I am also curious if this is the same that other product listed above with the 60 at the end of it//
    Lehigh Valley, PA
    The product is made by Lo-Chlor Chemicals and contains 11.83% copper sulphate pentahydrate and 83.17% inert ingredients. We don't recommend using any products containing copper. It is not the same as Polyquat 60.
    Anna's right. DO NOT USE THIS PRODUCT IF IT HAS COPPER IN IT! Contrary to popular belief, it isn't chlorine that turns hair green, it is copper!
  6. #16
    Found it.
    It's made by AllChem, and sold under a bunch of labels. HomeDepot has an MSDS available for it, here, under the HTH brand.
    The Doheny's "Lo Chlor" label is here.
    (both archived locally)
    It's just a copper algaecide:
    "Ingredients Found:
    11.83% of COPPER SULFATE (PENTAHYDRATE) (161)
    88.17% of INERT INGREDIENTS (0)"
    And, no, it will not keep your pool algae free for 90 days, unless you also chlorinate, filter, and otherwise do everything necessary.
    Ben
    Oops. Anna, I still had this open from last night, and didn't check to see if someone else had posted. My bad.
  7. #17
    Aug 2010
    Thanks for everyone's imput and help. I will cerainly go out and by some Polyquat 60. Any suggestions as to HOW MUCH and WHEN I should put this Polyquat 60 into my pool. Should I balance the chemistry, shock and THEN put it in? Run the filter with it in or just dump it in before I close up the pool. Many thanks again!!1
  1. Winter closing IG BBB Safety Cover - Best Chemical Balance prior to closing?
    By blue wolverine in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-16-2012, 04:36 PM
  2. I will be gone for two weeks...what to do with my pool?
    By True Blue in forum Pool Equipment & Operations
    Last Post: 06-17-2011, 06:30 PM
  3. Need new 24' AG solar cover, any suggestions?
    By famdog in forum Above-Ground Pool Construction & Repair
    Last Post: 06-11-2007, 01:46 PM
  4. any suggestions on using a cover on a small AG?
    By rastoma in forum Above-Ground Pool Construction & Repair
    Last Post: 08-18-2006, 10:29 PM
  5. Tips, suggestions on what type of solar cover to buy & where?
    By MTU 5.0 in forum Pool Equipment & Operations
    Last Post: 07-14-2006, 10:53 PM
