For now, go and add a 3-quart jug of plain, unscented 6% bleach slowly to the skimmer while the pump is running or slowly in front of a return jet being careful not to splash you or the liner. That will take your chlorine up to about 5 or so. You'll probably have to repeat the dose late afternoon and maybe evening. In fact for the first few days, you'll have to test and add bleach about 3 times per day until you get some stabilizer (cyanuric acid) in the water. CYA acts kind of like sunscreen for your chlorine. Without it, you lose all the chlorine to the sun really fast.
You're going to need a good kit. Do yourself a favor and order the kit I mentioned above. It will make your life much easier. In the meantime, go to Walmart and pick up cheap OTO kit (yellow and red drops). It will probably only register to 3, but you can force it to go higher with a dilution method described here:
http://www.poolsolutions.com/gd/how-...d-testkit.html
That is a temporary measure, not intended to be a replacement for a good kit.
Each time you test the cl, add enough bleach to get the chlorine level back up to about 5ppm. In this size pool, each quart of 6% bleach will add about 1.8ppm of chlorine. Use that as a reference to help you figure out how much bleach to add each time you test.
Also, once you get the OTO kit, test the pH and report back. You want the pH between 7.2-7.8 --- I like 7.4-7.6 best.
Get a small container of CYA somewhere. It is sometimes labeled as stabilizer, conditioner or balancer. Check the label ingredients. If it says cyanuric or isocyanuric acid, it is the right stuff. Your Walmart, Home Depot or Lowe's may have it. If not, go to a pool store to get it but don't let them talk you into buying a bunch of stuff. Start by adding about 2.5 lbs.slowly to the skimmer while the pump is running. Then, run your pump 24/7 for the next 4 days or so to give it time to dissolve in the filter. Do NOT add more until a week has passed and you check the level. (If you order that kit from Amazon, it might be to you by then and you can test your own CYA level. If not, you'll have to have the pool store check it for you.) Report back when you get that reading in a week or so.
After your CYA registers in your water, you'll be able to go to testing and adding bleach in the evenings only.
While you are at Walmart, pick up several jugs of bleach. You'll use quite a bit especially in the first week. Also, pick up a box or two of 20 Mule Team Borax to have on hand. You can find it in the laundry aisle. Borax is used to raise pH when needed. Don't add any just yet until you post your pH reading for us to look at. Also, get a jug of distilled water.
Hope this helps! Don't wait too long to get the bleach in there. It is unbelievable how fast an unchlorinated pool will turn green!
EDIT --- I forgot to tell you not to backwash your filter for the week that the CYA is in the filter dissolving. Otherwise, you'll end up just throwing it out. Since this is a fresh fill, you shouldn't need to backwash yet anyways. Also, read lots of posts here on the forum to learn a bunch. Also, read at our sister website www.poolsolutions.com
