Re: costo's thread - chemicals for above ground pool
I have been adding some bleach daily, approx a quart. I finally got a cheap kit today(have had the hardest time finding one believe it or not) and tested it. Ph was 7.5 but did not get a reading on chlorine level. Im assuming its because I dont have enough to register but not sure on this. I went ahead and put a whole jug of bleach in and about 2 lbs of CYA into the skimmer(started to put it into the return stream but it didnt circulate well enough and just fell to the bottom eventually so Ill be cleaning that up later im sure???).
