bumping this post up....
Since you subscribed instead of just doing the free trial member thing, I've emailed Ben to see if we can get your thread moved out into the open areas of the forum. Hopefully, someone will view it who can give you some help. Thanks for subscribing, by the way!
Welcome to the Forum!
As you already know how to access the o-ring, I'll tell you how to clean and lube it. (I can't tell you how to get to it from memory)
Fill a bucket with water and gently roll the immersed o-ring between your fingers, all the way around. Then use a Teflon or silicon based lube (petroleum based lube wrecks o-rings!!!) and, again gently, massage it onto the o-ring. (By 'gently' I mean DO NOT pull on or stretch the o-ring as you do these things)
