You can get by with your kit. I muddled by with one the last half of last year's swim season. Without the FAS/DPD test it's harder and actually more expensive when it comes to Chlorine use. Without the FAS/DPD, it's sorta like driving in the rain without windshield wipers. You can do it but sooner or later you're gonna run into something. That said, without knowing your CYA is like driving blindfolded from the backseat with no brakes.
You already have the CYA test in your kit. Knowing CYA is the lynchpin IMHO. Once you have an idea of how much CYA is in the pool, you know how much Chlorine to use in maintaining and shocking. Here's where the FAS/DPD shines and pays for itself.
I was at 90 CYA last year. I tried to keep FC at 10ppm. I used the dilution method with the OTO test. I stared at that color comparator till I was cross eyed. Does that color match the 5 or 3? Read it wrong and in no time you have a cloudy and/or green pool. I went through a lot of Chlorine. Figured too high was better than too low. I probably wasted the price of good kit in Chlorine. You can pick up a FAS/DPD kit for about 26 bucks-that's without shipping.
