Results 1 to 8 of 8
Thread: My Build
    vinper is offline Subscriber Thread Analyst vinper 0
    Texas
    Default Re: My Build
    Ok will try that ,thank you
    Your pics are below.
    Picture and attachment handling in this version of vB is completely different than it was before. You have the permissions, I believe, but it's an awkward process. I just tried it with my "subscriber" alter ego user ID, and didn't succeed quickly, so I just went ahead an created a PoolForum.Pics Picasa album for you. vB seems to totally change picture and attachment handling with each major upgrade, and then fail to create an upgrade process that resets the pictures. I've lost user pictures 3x, and have about had enough. So I'm emphasizing a PoolForum Google album. I don't know if I'll be able to keep that up, but at least the pictures that go there won't get 'lost'.
    Ben
    Jun 2011
    South West USA
    WOW! Such a beautiful pool! Love the planted rock areas, and I love the concrete decking......what color/type of decking is that? Also the color of the pool plaster looks great what product is that?
    Absolutely beautiful thank you for sharing the pictures!!!
    B.S.
    Texas
    Plaster Diamond bright(also called quartz) french grey... notice no waterline tile plaster goes all the way up. Has cantilever edge no coping ,tile decking goes right to water edge,rock insert's sit 10" below water line sticking out , auto fill , overflow,18,000 gallons. Do not remember what color cool deck a light Biege to match the house . Has oversized 2 1/2" pump suction lines ,600 sq ft. decking. 7 looped return line nozzles ,2-hayward color LED lights.2 skimmers, separate bottom drains 2 filter 2 for waterfall. and 2 rain type spray nozzles. I designed and sub contracted out the build. I did the electrical & purchased the equipment... Built and filled with water in 7 days ...been in now 2 years . Wife and I did the landscape /irrigation and the fence. have 24k in the pool $1800 in the fence.. next will be outdoor kitchen
    Texas
    diamond brite french grey
