Results 1 to 10 of 13
Thread: Is a Cheap Pool a Bad Idea?
    May 2010
    Default Re: Is a Cheap Pool a Bad Idea?
    I'd like to suggest that you look into and compare a couple of different things.
    #1, If you're really trying to save money, look into a 48" tall vs. the 52". The 4 inches might save you a bundle.
    #2, Liner thickness, the thicker, the better. But you could save a few bucks with a slightly thinner liner. also the plain liners are almost always cheaper than the printed ones.
    #3, Size of the top rail and vertical supports. I'd stay away from the low end like 2 inch wide stuff. 4" - 6" minimum. Also, the more vertical supports the better.
    #4, Thickness of the side wall. Probably not a whole lot of wiggle room on this.
    BigDave's Avatar
    Thanks BTDG ( your nick describes me well )
    1) At 52" the pool wall is an acceptable barrier.
    2) The cheapest pools do sport 20 mil liners.
    3) I haven't seen anything yet 2" wide. The cheapest I've seen are around 6".
    4) How thick should I expect, I haven't seen alot about wall thickness - coatings, corrugation, style, but not thickness.
    As this is ~ temporary pool, you should do well for a year or 2 with almost anything - but do take into account the things BTDG mentioned.
    Also, you're dead right getting the system for your upgraded pool now, that you can use on your 'new and bigger/ better' pool. (GOOD JOB!!)
    BigDave's Avatar
    Thanks waste,
    Is it possible to have buyer's remorse before a purchase?
    Thanks waste,
    I guess it's possible, but I wouldn't recommend it LOL
    BigDave's Avatar
    I bought the pool, it's in my garage. Now I need an installer.
    May 2010
    #1, I assume this means that with a 52" wall, you don't need a fence?
    #2, 20 mil liners are great but a thinner liner is plenty good and usually cheaper if you're only going for a few years.
    #3, More is better, a cheap pool can fail, I wouldn't skimp here.
    #4, Not sure, but my point is to compare different brands, again more is better. I had a 4x18 foot pool "Bulge" at the bottom because of too thin of side wall and vertical supports. The pool store and pool supplier came out to my house and installed "Stiffeners" to the vertical uprights to "Help". Which all could have been avoided if I had done a little more homework. But that pool is rusting away in a landfill somewhere, so all is good.
    BigDave's Avatar
    Thanks again BTDG.
    Yep, the pool itself is considered an acceptable barrier (fence) as long as there's nothing close that can be used to climb in. The ladders have an auto closing door that covers the steps on the outside.
    I appreciate your insight especially the story about your bulging pool - that is exactly the king of problem I want to avoid.
  1. Old Pool, New Idea
    By FishTale in forum --cleanup--
    Last Post: 10-16-2012, 09:00 PM
  2. A Cheap Pool Cooler
    By duraleigh in forum Pool Equipment & Operations
    Last Post: 08-19-2006, 10:41 AM
  3. brown stains along rim of pool, vitamin c does not remove stain, idea?
    By vinouspleasure in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-27-2006, 02:22 AM
  4. Cheap Cl? Check with your local pool store.
    By ChuckD in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-15-2006, 03:00 PM
