Re: liquid chlorine raising pH
The NET effect of adding sodium hypochlorite is close to pH neutral. It is alkaline when added BUT all forms of chlorine are acidic on sanitizing so that means that all of the unstabilized chlorine (sodium hypochlorite, calcium hypochlorite, and calcium hypochlorite) are essentially pH neutral and the main cause of pH rise is from outgassing of carbon dioxide. This can be lessened by lowering the TA, which should be between 80-100 ppm (or even slightly lower) when these are the primary chlorine sources in the pool. Second, the lower you put the pH the faster it will rise (because lower pH outgasses CO2 faster) so keeping the pH no lower than 7.6 will also slow pH rise in the pool.
When using acidic santizers (trichlor, dichlor, MPS, BCDMH, DMDMH) which are all net acidic then the TA should be higher, 100-120 ppm or even higher in the case of trichlor which is extremely acidic. This higher TA will have a faster pH rise to compensate for the constant 'acid' additions from the use of these products and keep the pH from 'crashing'.
Also, depending on how much sanitizer is added the pH can appear to rise after adding ANY chlorine or bromine source because of an interference between the halogen sanitizer and the phenol red pH test which causes a false high reading when sanitizer levels are too high. With some pH tests this can be as low as 3 ppm FC! With better tests (such as Taylor's) this is around 10 ppm sanitizer. The pH has not acutally risen as much as the test indicates and should be ignored until sanitizer levels drop to normal levels.
