Results 1 to 10 of 13
Thread: Salt Only
    vinper is offline Subscriber Thread Analyst vinper 0
    Jul 2010
    Texas
    Default Salt Only
    Does anyone use salt , because they like it. But still use the BBB method . No SWG ? positives /negatives of this .......Basically using salt for comfort and still treating with chlorine...
    Scottsdale, Arizona
    Default Re: Salt Only
    Yes. People do it all the time. I added enough to my neighbors pool to bring it to 2600ppm and they love the way the water feels.
    14'x31' kidney 21K gal IG plaster pool; SWCG (Saline Generating System's SGS Breeze); Pentair FNS Plus 48 DE DE filter; Whisperflow 1 HP pump; 8 hours hrs; kit purchased from Ben; utility water; summer: none; winter: none; PF:5.7
    Jun 2011
    Inverness, Alabama
    Quote Originally Posted by Phillbo View Post
    How do you get a reading on how much salt there is in the pool? I've got a Chlormatic and it reads 3.5 on the salinity. How does that relate to "ppm"?
    Jun 2011
    Inverness, Alabama
    Do you still have to use all of the other chemicals when you go "all-salt"?
    waterbear's Avatar
    St. Augustine, Fl
    Quote Originally Posted by PoolParadise View Post
    With a salt test kit or meter.
    Jun 2011
    Inverness, Alabama
    So does this method not use the SWCG?
    If so, where can I find more information on this method?
    It's not a "method".
    You may be thinking -- because some people talk as if it's so -- that there is a way to treat pools with salt alone. That is NOT true! Salt + an SWCG is just a METHOD of adding chlorine.
    Some people add salt, while still chlorinating through other means, because they like the 'feel' and because it lowers eye irritation compared to 'fresh' water. But that's all. Salt alone does NOTHING to sanitize a pool or prevent algae. If that's what you mean by "method", there IS no method.
    Good luck,
    While salt water can be generally more inhospitable to bacteria and viruses than fresh water, even if you have the ocean's salt level you cannot and should not rely on salt for any level of sanitation, and certainly not at "comfort" or even SWCG levels. DON'T DO IT!!!!
    Salt-water pools simply break salt, which is Sodium Chloride, down to extract the chlorine from it. THAT chlorine is used to sanitize the pool and is exactly the same as chlorine from bleach or powdered products.
    Jun 2011
    Inverness, Alabama
    Cool Re: Salt Only
    Quote Originally Posted by PoolDoc View Post
    Good luck,
    Ok, thanks!
    I was thinking "salt" like the ocean which does not have a chlorine generator to my knowledge. But thinking on this further, algae in the ocean isn't necessarily a bad thing. LOL
    Thanks for your clarification on this!
    Jul 2010
    Texas
    Well I added 220 lbs of salt , enough to slightly taste. I Like it ,feels better on my skin and contact lenses. Do I need a different test kit now . I know salt ph test is different. Any others ?
  1. Salt water system faulting high salt.
    By Skelly607 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2013, 10:43 AM
  2. Aqua Rite low salt reading when salt has been tested high
    By DirtRider67 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-19-2011, 05:58 PM
  3. Salt Level Keeps High without Addition of Any Salt
    By TooSalty in forum The China Shop
    Last Post: 08-13-2011, 01:56 PM
  4. Salt in a Non-Salt Water pool
    By wollypog6 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-31-2006, 10:01 AM
