Re: Salt Only
vinper
Well I added 220 lbs of salt , enough to slightly taste. I Like it ,feels better on my skin and contact lenses. Do I need a different test kit now . I know salt ph test is different. Any others ?
NO, all of the tests are the same, including pH. If you are talking about aquarium test kits then it is true that the pH tests for freshwater and salt/reef tanks are different but that is because they are kept at different pH and thetests are optimized for the pH range of the tank. Pools are kept at the same pH range whether salt or not.
