Thread: From Gunite to Vinyl...
    Apr 2011
    Broken Arrow, Oklahoma
    Default From Gunite to Vinyl...
    Hello all,
    Thank you for the site as it has helped me greatly the past three years. We just sold our current home to get a larger home for the kiddos and are moving from a gunite pool to a vinyl liner pool. What are the major differences in terms of maintenance or things I need to be prepared for that I did or didn't have to worry about with my former pool?
    Thanks!
    Jason
    Default Re: From Gunite to Vinyl...
    Welcome to the forum!!
    I've never owned a gunite pool, but I do have a vinyl IG...to me, seems that it would be much easier to keep up. Aside from obvious things like not letting the liner get ripped, there's not a whole lot of difference--calcium levels are not as important, and you have to be a little more careful about chlorine levels going way beyond the recommended levels per your CYA (see the "best guess chart" in my sig), but other than that, I can't think of any real differences, at least from a water quality point of view...
    Just remember not to use a wire brush on it...or ever let it get empty. An empty gunite pool can "float" out of the ground, but not if there's no ground water. If you let a vinyl pool go dry the odds are you'll have replace the liner.
    About every 5 years or so hard-sided pools seem to need serious maintenance, like re-surfacing or painting. A well-maintained vinyl pool can go 10-20 years without replacement, though at 10 you may need to think about a liner.
  1. Gunite already calcium deposits and small hairline cracks of both plaster and gunite
    By getittogether in forum In-Ground Pool Construction and Repair
    Last Post: 04-10-2011, 01:45 PM
  2. Thinking of going vinyl rather than gunite
    By jbhogfan in forum In-Ground Pool Construction and Repair
    Last Post: 11-19-2006, 09:08 PM
  3. safe depth to drain vinyl pool w/vinyl stairs
    By ScottsdaleSwim in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-13-2006, 01:47 AM
  4. Vinyl Coping for overlap IG vinyl pool
    By SLS in forum In-Ground Pool Construction and Repair
    Last Post: 06-22-2006, 09:57 PM
  5. Gunite -vs- Vinyl lined
    By Pool_Mike in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 03:51 PM
