I have checked ours frequently and have had no incidents of algae behind or under the steps or the pad. I do pour bleach to the right of the steps so it moves with the flow through them when cleaning or brushing about, just for good measure
Exactly. Luck may have it. We purchased a mat too large for under the steps on purpose from water warehouse. It was only about 35 $ if I remember correctly.( it's far cheaper than a new liner down the road) Any how, instead of algae building up on the liner of the pool that you CAN NOT get to without removing the steps, it builds up on the mat itself. We pulled it out from the front and put the hose spray nozzle on "jet" and within 10 seconds it was clean as a whistle. It can be done by yourself, but the extra two hands helps out. Next year I plan to scissor trim the part of the mat that sticks out of the front left and right, but it is only because it tends to "flap" and the barracuda gets caught under that flap sometimes. So, to protect your liner AND have an easy way to clean "under" the steps this is awesome. Between your "weight" idea and my "mat idea" the step situation is A-OK! Opening the pool the first wknd in may, this is the first time since then that we have had to "pull the mat". I was instructed to use polyquat 60 one week and algae control concentrate (guardex) the next. It is because of the resistance of different types of algae, you need different types of algaecide. I only get small spots of algae here and there and staying on top of the problem gives us more time to swim and not clean. There is however algae in the bottom most step where the weights are, but it hasn't so far seemed to want to creap out. Turkey basting seems to help, it could only be in my head, but hey, squirt it where you can't pour it right?
GOOD LUCK
check out your size mat here:
http://www.waterwarehouse.com/products/sku-6586.html
30' Esther Williams Classic Granite
Installed july 2006
