Thread: New AG pool owner with questions
    Jun 2011
    Default Re: New AG pool owner with questions
    Ok, so I went to Walmart and bought the only test kit they had... It's a cheap'o 3-way, but it will have to work until the good one gets in. My pool is going to be installed tomorrow so, I filled up a glass with water from the hose I'll be using. Here were the results from that test kit:
    CL - 1.5
    BR - less than 1.3
    Ph - 7.6
    Any tips on getting this thing up to speed? I've got the baking soda and I'll get a few gallons of bleach (6%, right?). When I add the bleach and stabilizer, will that 'shock' the pool?
    "Shocking" usually just means "getting the chlorine to a kinda high level".
    Your fill water looks like it may be easy -- as long as the inside of your toilet tank is not DARK brown / rust color, you should be OK.
    If you want to swim ASAP, do this.
    #1 - hang the stabilizer in a sock in front of the return. It's slow to dissolve, and you'll lose it if you have to clean the filter before it's completely gone.
    #2 - go to a pool store if you have to , but get some polyquat (see www.poolsolutions.com/gd/polyquat.html) and add it AS SOON as you begin filling. It's safe to swim in, at any concentration, but will prevent algae and contribute to sanitizing the water.
    #3 - start the pump as soon as you can, and put the sock in place.
    #4 - add 1/2 gallon of bleach to the pool the first evening it's full.
    #5 - unless something funky happens with the water -- possible if there's something weird in the water -- start swimming the next morning.
