You will find that the DC volts go up and the DC amps go down, indicating a higher resistance between the membranes as the coating wears out. The chlorine output starts to go down as well.Originally Posted by tonyl
In your case, you appear to have a cell that seems to "rejuvenate" itself.I would expect that might happen if you acid wash the cell at the end of the season, but I suspect something else might be happening. It should lose efficiency as it gets to the end of its life.
Hope this helps.
Pat
Pat
