Thread: Ok to fill pool using well water?
    Lehigh Valley, PA
    Default Re: Ok to fill pool using well water?
    We use our well to refill/replace water in the pool. We run it 2 hours (the well pump puts out 4 gpm) and then shut it off. If we need more water, we wait 6 hours and run it another hour. We ran the well dry one year after planting 23 White Pine which had to be watered. Not doing that again!
    Honesdale PA
    Welcome to the forum Dan,
    I initially filled my 22K gallon from a single well in 1997 and the only problem I had was silt and mud from sucking so much from the well. Tt is easiest on a well pump if you run it continuously assuming you don't run the well dry. I ran three garden hoses right from the pressure tank so the pump never shut down. Cycling is what kills well pumps. I filled mine in the fall so it had all winter to let the muck settle. If you're gonna do this save a bunch of drinking water ahead of time in case you stir things up. I don't use my wells for the pool now but top off from a small stream. I guess I was lucky in that I never checked for metals and never had a problem with the initial fill.
  1. If this was your fill water, what would you do?
    By Bosch232 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-04-2013, 09:13 PM
  2. Filling Intex-type pool with well water!
    By PoolDoc in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-23-2012, 12:14 AM
  3. Fill with only 1 foot of water and don't fill for 24-48 hours?
    By Jacob99 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-26-2012, 07:00 PM
  4. Pond water used to fill pool, NEED HELP!
    By parealtor in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-05-2006, 02:04 PM
  5. Which water to fill with - softened or reg
    By SoCalBoo in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-26-2006, 08:02 PM
