Thread: Low flow on intex saltwater/sand system?
    Jun 2011
    Question Low flow on intex saltwater/sand system?
    I bought this maybe 2 months ago, it's the intex saltwater and sand filter system. It ran fine (4 hours a day) for a week or two. It's now having a low flow problem. I tried backwashing (then of course rinsing as the manual says), i checked all of the hoses, and the flow sensor, nothing is blocked.
    I tried running it again and it had great flow, for maybe 10 min, then I saw the flow sensor 'falling' some, another 10-20 min and it's beeping that there is low flow. The flow sensor was maybe halfway up (to where it should be).
    So I can see that it's not a sensor problem, but i have no idea why it keeps loosing flow. It's about to drive me crazy. I've had to have it off for a week now.
    Default Re: Low flow on intex saltwater/sand system?
    I can't trouble shoot your unit for you, but I can tell you that you can run your pool as a conventional chlorine pool while you work this out. If your stabilizer level is OK, plain 6% bleach works fine.
  1. Low Flow error with Intex saltwater system
    By lucky4you in forum Intex-type Pool Setup & Operations
    Last Post: 07-30-2012, 11:13 AM
  2. Intex Salt system and Sand Filter Question
    By 2manycars4me in forum Intex-type Pool Setup & Operations
    Last Post: 07-18-2012, 01:03 AM
  3. Doughboy AGP and an Intex Saltwater system?
    By Drpepper in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-28-2011, 02:33 PM
  4. Intex saltwater system
    By LeeDavenport in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-31-2011, 07:31 PM
  5. Intex saltwater system
    By chasamp in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-31-2010, 10:31 AM
