Results 11 to 14 of 14
Thread: Pump Sizing Question
    BigDave's Avatar
    Default Re: Pump Sizing Question
    Right now I'm trying to convice myself that a variable speed pump is the way to go. Install a flowmeter and set the pump to meet the flow requirements of filtration or the solar based on test and not "Wild Guess" estimate of piping / filtration / heat system in operation before being built.
    cons:
    Expensive
    pros:
    Potential to save on electricity ( I haven't calculated what it would take to break even on that )
    Use only what we need to run the gear not use what the pump requires
    Maintain optimal flow rate for each configuration
    Can be adjusted as our needs change
    Can self prime making it useable if we do get an IG
    Keeps me from having to go through estimating the requirements of a system that doesn't yet exist and living with it later
    Sounds like I'm taking myself into it.
    BigDave's Avatar
    PoolDoc
    I will send the curves if I get 'em. All I've gotten so far has been and auto answer email "We have recived your inquiry and will respond as soon as possible..."
    mas985's Avatar
    Pleasanton, CA
    Again, the head curves are on this web page if you don't want to wait for Hayward. It is a table under "Performance Data"
    Mark
    BigDave's Avatar
    I got that Mark and thank you very much. That table is partly what's pushing me toward Variable Speed - I'm not there yet, but trying to work my head around it.
  1. Question about Pump/Sand Filter Sizing
    By NTL1991 in forum Pool Equipment & Operations
    Last Post: 08-11-2012, 11:39 PM
  2. Pool Filter & Pump Sizing Question?
    By zooba72 in forum Pool Equipment & Operations
    Last Post: 06-17-2012, 11:02 PM
  3. Question on PB's pump sizing
    By txborn in forum Pool Equipment & Operations
    Last Post: 10-27-2006, 02:26 AM
  4. Pump Sizing Question
    By liz+3 in forum Pool Equipment & Operations
    Last Post: 06-27-2006, 10:45 PM
