Results 1 to 10 of 22
Thread: No kit yet -- Opened Pool -- What Should I do?
    Default Re: No kit yet -- Opened Pool -- What Should I do?
    You don't have Br (bromine) in your pool--disregard that scale, and pay attention only to the pH and Cl on that test block. If your Cl is registering low (or nonexistant), add enough bleach to get your Cl up to at least 3 ppm. YOu also need to test for CYA asap, because if it's high then you need to take the Cl up higher.
    And I'm with Ron on the CYA thing--chances are you don't have any in your pool, but if you do, you don't want to add any more, so don't do so until you've tested for it!
    Tinley Park, Illinois, USA.
    Thanks all for your help.
    Is there a way for me to test CYA if it's not in the Walmart OTO kit? Should I bring a water sample to the pool store?
    In the meantime since I don't know what the CYA is, should I still add the bleach and muriatic acid or do I wait until I know what the CYA is?
    duraleigh Guest
    Hi, Anna,
    I think you should add just the acid for now. Sooner rather than later. That'll get your pH in line.
    Yes, get your CYA tested at the pool store and post back as soon as you can.
    It wouldn't hurt to put the Cl in there now but the most effective dosage will be after we know your CYA.
    If it's gonna' be days before you get your CYA results, go ahead and put the Cl in anyway....you need some preventative sanitizer.
    Hi Dave,
    We put in another jug of chlorine this morning (96 ounces) and have the pump running. I will run to Home Depot to buy the acid and stop at the pool store to get my water tested.
    Is there a calculator to figure out how much acid to put in my pool (approximately 15,000 gallons) and how much chlorine I should be putting in also?
    Thanks so much!
    Anna
    duraleigh Guest
    Search for a post by mwsmith2....there's a handy calculator in his signature.
    Post your CYA test as soon as you can....probably 0 but post it up.
    Thanks Dave.
    It's been raining two days solid with temps in the 40's. We've just kept the pump running about 6-8 hours per day and added one jug (96 ounce) of chlorine.
    Still hoping to get my kit soon. But, since today is Saturday and I don't have to work, I will take my pool water to be tested at Leslie's pool supply. I promise I won't buy anything!!!!
    Anna
    24' Above Ground Pool x 54" depth -- 14,000 Gallons (approximately) -- 1 1/2 HP Hayward DE Filter (model EC 45) -- Hayward H150 Gas Heater
    duraleigh Guest
    Anna, if they test CYA @ zero, get three lbs from them and put it in your pool. This should bring you to about 30ppm and will help you keep Cl in the pool. If they test higher than zero, buy enough to bring your CYA up to 30-40ppm (you have 13,500 gallons in your pool).
    Your gonna' need some more Cl. Buy some bleach while you are out and we'll help you on quantity when you post some test results.
