Filter question
Hi, Newbie here! My filter doesn't seem to be closing completely on the inside. When it's on filter, water is coming out of the waste/backwash pipe in the yard. It's seems like it isn't completely closing the valve of the inside when you switch it to pump. Not able to run the pump because the water is draining in the yard. Any ideas, suggestions? TYIA!
- You may not post replies
- You may not edit your posts
Forum Rules
