Thread: Polaris PB-4 Booster Pump
    South Jersey
    Default Polaris PB-4 Booster Pump
    Long time reader, first time caller.
    I need some advice, and I truly value the opinions of the people here.
    HISTORY:
    Long story short, my Polaris Booster pump ruptured a flex line (that was not installed correctly) last summer and was out of commission. So far this year I had a trusted local pool company replace the flex lines (installed correctly) and a good deal of the leaky plumbing/valves and the main pump.
    Very excited to have my Polaris back in action, I fired it up a few nights ago but after 5 minutes, water started pouring out of the shaft seal on the booster pump.
    No big deal, local pool store had the shaft seal in stock.
    PROBLEM:
    The problem is the impeller is frozen to the shaft. Being 11 years old it was also brittle, and cracked when I tried to remove it.
    QUESTION:
    I am asking for opinions/advice on whether you think I should replace the impeller or replace the whole pump.
    At this point the remains of the impeller are still stuck on the shaft. If you think I should replace the impeller and salvage the pump any idea how to get it off?
    Thanks in advance.
    vinper is offline Subscriber Thread Analyst vinper 0
    Texas
    Default Re: Polaris PB-4 Booster Pump
    If plastic impeller you can heat with heat gun or use a hacksaw blade cut slot down to shaft , some are pressed on some screw threads, and you need to know if clockwise or counter clockwise threads.
  1. polaris booster pump
    By kimrob in forum Pool Cleaning: Manual or Automatic
    Last Post: 12-09-2012, 02:19 PM
  2. Polaris booster pump hose needs help
    By dawndenise in forum In-Ground Pool Construction and Repair
    Last Post: 08-28-2008, 10:53 AM
  3. Polaris booster pump rebuild
    By biker2 in forum Pool Equipment & Operations
    Last Post: 10-01-2006, 01:03 PM
  4. Polaris Booster Pump Rebuild
    By vgg659 in forum Pool Equipment & Operations
    Last Post: 08-27-2006, 12:27 PM
