For a 40K pool with algae,
#1 - dump 10 gallons of 6% household bleach in late this evening.
#2 - use a cheap OTO/phenol red drops testkit (Walmart, Kmart, etc.) to test BEFORE adding bleach; report results.
#3 - Order a Taylor K2006 or 2006C kit. (Amazon links in sig -- make sure seller is "Amato Ind", others substitute K2005, as of this AM, you'll have to buy the 2oz bottle version - 2006C)
#4 - Post, but do not trust (we won't!) the pool store tests
#5 - Make sure your pump is on 24/7 till pool is all cleaned up.
#6 - If you got to the store, do NOT buy any goop. You can purhase polyquat 60 (see www.poolsolutions.com/gd/polyquat.html) and use that, but only when the chlorine is below 5 ppm (ie, not tonight)
More after you post info!
