Thread: No change in CYA
    Default Re: No change in CYA
    You probably are just between 25-30ppm which is hard to distinguish on the test. Go ahead and add 2 more pounds. A week later, test again. That should put you right around 40 which would be a good level.
    Jun 2011
    Southwest Arkansas
    Thank you for the information.
