Thread: AGP and 1hp Pump... Calculate Turnover?
    Jun 2011
    Default AGP and 1hp Pump... Calculate Turnover?
    I've been lurking around this forum for around a year now (since we built our house last year and I knew I wanted a pool). At one time I found a thread that discussed turnover rates and recommendations. Unfortunately I can't find it now.
    I have a Sta-Rite OptiFlo 1hp 115v pump attached to a DE filter with 1 1/2" hoses. My pool is a 15'x24'x52" pool (I think around 9800 gallons). I'm using the BBB system (still working on getting everything settled in as the pool just went up last week) and I'm in Southern NH. Looking for any advice on turnover rate and how often I should run the pump (as I'm planning on putting a timer near the breaker panel). Thank you!
    Shane
    Default Re: AGP and 1hp Pump... Calculate Turnover?
    Not sure which thread you wanted, but you can find a bunch by searching here:
    http://www.poolsolutions.com/search.html
    Here's the Pentair manual, with flow rates:
    http://www.pentairpool.com/pdfs/stariteoptifloDS.pdf
    Assuming 50GPM, you will 'turnover' your pool every 2 hours. So, (2) 2 hours runs should work OK. But you'll need more with thunderstorms and such. Also, if you use a timer, do NOT put tabs in the skimmer. Instead use a floater.
  1. If you run a variable-speed pump at half-speed, does the turnover rate double?
    By famousdavis in forum Pool Equipment & Operations
    Last Post: 07-25-2012, 01:22 PM
  2. Turnover rate per day/Pump run time and GPM
    By 26theone in forum Pool Equipment & Operations
    Last Post: 03-10-2007, 02:52 PM
  3. How do you calculate head?
    By Rangeball in forum Pool Equipment & Operations
    Last Post: 07-17-2006, 12:32 PM
  4. Pump turnover rate
    By waldreps in forum Pool Equipment & Operations
    Last Post: 05-07-2006, 12:48 AM
  5. How to Calculate Feet of Head...???
    By Sherra in forum Pool Equipment & Operations
    Last Post: 04-12-2006, 04:58 PM
