My Raypak RP2100 is about 11 years old. It runs for 4 to 8 hours then shuts off. There are no error codes displayed. Any ideas? Thanks.
Any help for this poster?
have you tested the water pressure switch and on/off switch for continuity? Check the thermostat for resistance? Have you put the thermostat all the way up to see if it will run longer? I have the older raypack (manual thermostat) and have had to replace the pressure switch a couple times...
