Results 11 to 12 of 12
Thread: Chlorine Lock
    Default Re: Chlorine Lock
    Your TA is too high, but nothing to worry about at the moment . . . except that you'll need to keep adding acid to keep you pH below 7.8
    BUT . . . your chlorine is too low! Are you adding 2 gallons of bleach each PM?
    If you have the Taylor FAS-DPD test kit you cannot get "FC =2 and TC=1". Perhaps you mean CC= 1 rather than TC?
    Rule: TC = FC + CC. Therefore TC can NEVER be less than FC.
  1. Chlorine Lock
    By wellioughta in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-11-2011, 12:07 AM
  2. chlorine lock?
    By skimmer in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-08-2011, 08:40 AM
  3. Pool guy says Chlorine Lock?
    By Mwil3 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-28-2010, 10:31 AM
  4. Help!! I don't know who to believe - Chlorine Lock?
    By btozzo in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-24-2010, 05:31 AM
  5. Chlorine Lock ????
    By poolrescue30 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-18-2008, 06:12 PM
