Results 1 to 10 of 20
Thread: Fighting Cloudy Water: 4 Weeks and Counting
    Jun 2011
    Franklin, TN
    Default Re: Fighting Cloudy Water: 4 Weeks and Counting
    Well, it's been a couple of days and things are looking up finally. I can actually see the bottom of the deep end for the first time!! Water is still cloudy, but levels are starting to even out.
    I'm in full-on BBB mode, making the switch to bleach for chlorination over the weekend.
    My biggest problem is I still can't maintain a steady FC level. It went from 14.5 down to 9 in 24hrs. I added 1.5gal of bleach to get it back up tonite. My CC is steady at 0.
    pH jumped up to 7.8 last nite, but I let it ride and was back down to 7.4 tonite. Do you think it might have been a false high read because chlorine levels were so high? Hope it stays in the good zone overnite.
    TA is steady at 90. Should I raise it up closer to 100 or leave it? Thinking maybe raising it would help steady the pH.
    I also have A TON of tiny particles of sediment too fine to catch in the skimmer net from all the months of neglect. I would assume this is contributing to the cloudy water. Any way to speed up the process of getting those cleaned out or do I just have to be patient and let the filter do its thing?
    And, last thing to note based on comments earlier last week about a broken heater causing water problems. My water is in fact running thru the broken heater right now. One of my bypass valves froze and cracked over the winter, so I actually had to rig the pvc piping to go around the cracked valve; much cheaper than buying a new valve. But, I am thinking maybe I should re-reroute the piping to bypass the heater all together just to be safe. Any thoughts on this? Could it be contributing to the cloudy water?
    Thanks,
    -A
    Glad things are improving. Be consistent with maintaining high cl levels while the water is cloudy. Are you testing your pH while the chlorine is high? That will give false high pH. With the Taylor K-2006, you can test pH if the chlorine is lower than 15 which is higher than most kits will allow. I wouldn't worry about raising alk any right now.
    You can try a little trick that some of us use to help our sand filters filter a little more efficiently. Adding a little DE will help you filter out smaller particles than your sand can get by itself. Read more about it here:
    http://www.poolforum.com/pf2/showthread.php?t=3742
    I can't help with the heater issue. Somebody else will hopefully chime in about that.
    Hope this helps.
    Jun 2011
    Franklin, TN
    So things are still overall doing well. Pool is staying clear. Still a little cloudiness in the deep end, but I can clearly see the bottom of the entire pool and it's a nice blue color.
    pH is holding steady @ 7.4 and TA @ 80-90. My problem continues to be Cl levels. I can't hold a steady reading. I've been trying to keep it above 10ppm (using bleach only) until the water is definitely cleared up, but it's been dropping as much as 3ppm in a 24hr period. It did only drop 1ppm from sundown last nite to sunup today: 8.5 - 7.5, which seems like a positive sign. I checked my CYA this AM again just to be sure, and it's still @ 30-40ppm. Any idea why I can't hold Cl levels when everything else is stable? Is there something else I need to do?
    My next question: I want to try to swim in it this weekend for the 4th. Am I ok to let the Cl levels drop into the 3-6ppm range for swimming and just monitor it closely, or do I need to maintain shock levels still?
    Thanks as always,
    -A
    You aren't going to be able to keep cl at an exact level in a pool. Not expected. Losing 3ppm in 24 hours is totally normal. You're not going to keep a steady cl level unless you are adding chlorine frequently through the day. I take my cl up to about 6 in the evenings, (my CYA is about 30 right now) and by the next evening, I'm down to about 3 or so.
    Have you checked the CC reading lately? If you have no more than 0.5ppm of CC and are losing no more than 1ppm of cl overnight, then go ahead and let the cl drift down but don't let it get below your range based on your CYA level. But, continue running the pump 24/7 to try and let the filter clear it up. And, be careful with swimmers in cloudy water -- especially in a deep end. Make sure you are watching closely! Then, if needed, you can raise the cl levels back up after the weekend.
    Jun 2011
    Franklin, TN
    Thanks Watermom.
    CC has been holding steady @ 0 -.5 for the last week. I'll go ahead and let it drop and start the regimen of maintaining the 3-6ppm range like you said above.
    Did you mean this in terms of making sure I can see them and know that they are safe? If so, that is no problem. The water is completely clear enough for good visibility and safety.
    Last edited by Watermom; 07-02-2011 at 11:29 AM. Reason: change 36 range to 3-6 range
    Quote Originally Posted by anixon7 View Post
    Yes, that's what Watermom meant--in very cloudy water it's hard to tell sometimes if somebody's in trouble. If you can see them clearly, that's great!!
    Jun 2011
    Franklin, TN
    Pool's finally open!!!! Thanks so much to the Forum, especially Watermom and Janet, for helping me get here. You rock!
    Check out the before and after pics. Hopefully they attached ok.
    -A
