Thread: Running the filter while it is raining
    Jun 2011
    Southwest Arkansas
    Default Running the filter while it is raining
    Do most of you turn your filter off or leave it running when it rains?
    Love the BBB method
    AG 19,000, Sand Filter, 1st Season using BBB and loving our pool.
    Default Re: Running the filter while it is raining
    I leave it on.....no reason I can think of to turn it off, unless you have hurricane-style winds blowing enough leaves and stuff into the water to risk stopping up the skimmer basket.
    Same with me. It goes on at 6:30am and off at 8pm (I run on low speed).
    Me, too. Unless my solar panels are on and I am too lazy to go outside and flip the lever to divert water away from the panels. If that is the case (me being lazy), then I'll just go downstairs and flip the switch that turns my pump off. Otherwise, it stays on when it is raining.
  1. Losing water when filter is running
    By sztaylor in forum Pool Equipment & Operations
    Last Post: 10-04-2011, 10:07 PM
  2. Pool Filter Running Time
    By mikerond in forum Pool Equipment & Operations
    Last Post: 06-07-2011, 01:49 PM
  3. help Need to get my Filter Running
    By OldPoolNewOwner in forum In-Ground Pool Construction and Repair
    Last Post: 08-10-2006, 08:32 PM
  4. help! Filter not running
    By jabbajean in forum Pool Equipment & Operations
    Last Post: 08-04-2006, 09:38 PM
