Help with leaks in new pool!
You all are such a great resource, so help me please! Brand new IG vinyl liner pool, filled with water last week, and has done nothing but leak since then. In 5 days time, pool has leaked from halfway up the skimmers, down to where there is only about 1 foot of water in the shallow end. And it is still leaking. We did notice some wet areas around the pool equipment. Pool guy came yesterday, said they had to re-do all of those plumbing lines anyway because they were put in BACKWARDS (!), and would check to see if that was the leak. Came home yesterday to have him tell me that the leak was behind the steps, where the "steps strip" was attached. He says he fixed that. Well, since then, pool has leaked an additional 5 inches (in 15 hours), so while that may have been leaking, that was not the main leak. We know it is leaking some around the equipment, so now I'm thinking "multiple leaks"!
It has leaked to well below the skimmers and the light, so that's not it. Could that much water be leaking at the pool equipment? We don't have standing water there, but it does seem wetter than the surrounding areas. Where else could the leak be? Main drains? Piping under the decking? Is the only thing we can do is wait and see where the water is when the leak stops? If it has leaked below everything but the main drains, could anything else be the problem? I need to know if I should be demanding more from my pool guy, because he is acting like this is no big deal. It is to me. We were supposed to have my daughter's 8th birthday party at the pool in 5 days, and now that is not going to happen.
Judy
