Re: Help with leaks in new pool!
Be patient with your builder - and give them sufficient time to correct the problem on the new build.
However sufficient time to me would be 1 or 2 weeks. If your not fixed and good to go by then - I'd have an attorney write up a letter to get them back on track. If you don't you could spend your summer chasing that leak - instead of enjoying your new pool.
Good Luck!
