Re: Help with leaks in new pool!
Newer update...all is still well. Pool heater is going, and the water is up to 83 degrees. And outside temp was 49 degrees last night! Only problem is we unhooked the Polaris to put away for a while, and the fitting that hooks it to the side of the pool is cracked. I feel sure either the pool guy will work with us, or we can have it repaired with the warranty.
Looks like my daughters birthday pool party is back on!
Judy
