Closed Thread
Thread: Electrical outlets around pool.
    beary is offline Registered+ Thread Analyst beary 0
    Dec 2005
    Default Electrical outlets around pool.
    Hi All, we are building a new pool in a couple of weeks and I was wondering if it is a big deal installing a couple AC outlets around the pool for the robotic pool cleaners. What did you do?
    Beary
    Default Re: Electrical outlets around pool.
    Just check your local codes--they have to be a certain distance from the water and they MUST be ground-faulted. (for your own peace of mind, ground-faulting should be your own mandatory requirement). They may also be required to be a certain distance from the pump power supply, and on a different circuit.
    Indiana.
    Yes, you are probably required by code to have one nearby to avoid the temptation of using an extension cord. GFCI without a doubt.
Closed Thread
  1. Old plastic water outlets and skimmer are old and ugly (yellowish)
    By joecus in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-24-2012, 08:18 PM
  2. New pool with electrical shock
    By Jose263 in forum In-Ground Pool Construction and Repair
    Last Post: 09-05-2011, 01:01 AM
  3. Electrical costs for my pool
    By rpoldervaart in forum Pool Equipment & Operations
    Last Post: 07-20-2006, 01:30 PM
  4. Electrical for pool
    By us7sail in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 02:49 PM
  5. New electrical subpanel for IG pool
    By Zaphod in forum Pool Equipment & Operations
    Last Post: 04-30-2006, 12:17 PM
