Thread: How to check for DE filter "leak"?
    Default How to check for DE filter "leak"?
    I have a DE grid filter w/ a multi valve and am getting a small amount of DE back in the pool (but it's hard to tell for sure or if it's just dirt). I am getting abnormal algae issues compared to normal which also makes me suspect something is wrong.
    A visual check of the filter appears fine, no torn grids, and I put a new spring in the multi valve.
    But is there any way to tell for sure, maybe something I can put in the skimmer to tell if my DE filter is leaking or not?
    Thanks.....
    Jun 2011
    Louisville KY
    Default Re: How to check for DE filter "leak"?
    If you have DE coming out of the inlets then you have too much DE in the filter.
    Backwash it thoroughly and weigh out the proper amount of fresh DE. Mix it into slurry in a big bucket. Start the filter, release any trapped air and pour the DE in the skimmer.
    Excess algae can cause this also. Dealing with algae is another topic all together.
    Circa 1980 IG, VL, 36K Gal, DE, Chlorine
    Jun 2011
    Be sure to check each of the grids thoroughly. I've had several (Hayward Pro-Grid) come un-stitched at the bottom end.
    If you have the grid assembly apart, look down the tube (from the top) of each grid for cracks and breaks.
    Breaks will be obvious when looking through the hole, and the broken plastic can cut through the fabric.
    But I think Manslick is right, sounds like too much DE
  1. Jandy LRZ "Check IGN Control"
    By nowazzu in forum Pool Equipment & Operations
    Last Post: 04-10-2012, 04:41 PM
  2. Pool Pilot error message: "warning check/clean cell"
    By cscannon in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 10-21-2010, 10:03 PM
  3. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 09:17 AM
  4. "Check System, No Cell Power" Error - Aqualogic PS-8
    By Geeper in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-27-2008, 07:08 PM
