Results 1 to 10 of 11
Thread: Best way to add cya,stabilizer?
    xoroniox is offline Registered+ Thread Analyst xoroniox 0
    South Florida
    Default Best way to add cya,stabilizer?
    I know this question has been asked before but i just finished searching through the whole section and didnt find a proper answer, maybe its hidden within another thread/section anyway.
    My question is what is the best way to add CYA. I have read adding to the skimmer and keep pump on, put in a sock in front of a return also put in the net and leave in front of a return. dissolving in a bucket of water than spreading the water around the pool. just dumping it in and let it dissolve. I need to add like 2-3pounds to my pool so i am wondering which method will work best for me.
    Thanks for all the help
    Poughquag, New York, USA.
    Default Re: Best way to add cya,stabilizer?
    Based on other advice, I got some skimmer "liners" (for want of a better word). These are about $8 for 5 at Leslies and other places. They are a fine mesh, soft nylon (I think) liner that fit right into the skimmer basket. Most people use them to have the skimmer filter out some of the finer stuff so it doesn't hit the filter.
    But, they also work great for CYA. I dumped about 3 pounds into one of these in with the filter running and within 24 hours all of the CYA was gone. Probably not completely dissolved, but at least small enough to fit through the really tiny mesh. Plus, these liners filter out a lot of the small stuff that goes right through my baskets.
    South Florida
    hey,
    Great, i think they are called skimmer socks. that is the method i will use... sounds good plus having extra filtration cant be a bad thing lol.
    -Arron
    cygnusecks is offline Unconfirmed User Thread Analyst cygnusecks 0
    Orlando, FL
    Just pour slowly into skimmer. I dump a 4 lb. dose of CYA over the course of two minutes. CYA tends to clump, so don't dump it all in at once. Slowly pouring means it'll find its way to your filter and dissolve there. I think it would dissolve much faster evenly spread out over your filter, vs. in a big clump in a skimmer sock.
    Quote Originally Posted by cygnusecks
    If you use this method (which is a perfectly fine method) do NOT back wash your filter for a week after all the crystals are gone. Otherwise a lot of CYA will be stuck in the filter and back-washed out!
    Whenever I feel the need to raise my CYA I just start chlorinating with either Tri-Chlor pucks or Di-Chlor powder, whichever I have on hand.
    Kentucky
    I just use a nice large gym sock (tube sock) fill it with the appropriate amount of stabilizer and let it soak in the skimmer basket.
    Ontario, Canada
    Quote Originally Posted by PhantomAndy
    And the Winner is Tube sock.
    Kentucky
    On another note - iv'e heard old panty hose (or Knee Highs) do a swell job too.
    Quote Originally Posted by CarlD
    That's what I do.
    Saint Cloud, FL
  1. Is stabilizer necessary?
    By JimK in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-29-2012, 07:48 PM
  2. Stabilizer
    By cooper in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2011, 10:26 PM
  3. Stabilizer
    By Sue225 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-12-2011, 01:22 AM
  4. Stabilizer
    By Calcutta in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-26-2008, 11:31 PM
  5. Stabilizer
    By mackeeg in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-17-2007, 01:16 PM
