Thread: Cleaning a Hayward DE Filter System
    Jun 2011
    Default Cleaning a Hayward DE Filter System
    OK, so I'm a relatively new pool owner with a few questions about my Hayward DE filter and the systems that operate my pool...
    My system uses a Hayward Separation Tank to keep the used DE from flowing out with my waste water... I believe it's simply placed inline with the waste water plumbing. I've only ever used the separation tank on the BACKWASH valve setting.
    My question is:
    Can I use my Separation Tank on the WASTE setting to clear out some of the muck in the bottom of my pool?
    My thinking is that the WASTE setting will bypass the filter, but run through the separation tank where the bag will catch most of the solids. Please correct me if I'm wrong.
    Default Re: Cleaning a Hayward DE Filter System
    Have never used a sep tank, but I'm guessing it's in the discharge line, which is shared by both the backwash and waste settings on a multiport valve. However, your pool may be plumbed differently.
    Jun 2011
    Thanks for the reply.
    I've spent most of the day getting to know my pool filter system and think I have a better understanding now...
    The Separation Tank is plumbed into the discharge line as you stated.
    It looks like there are several ways to run the vacuum system and it's just a matter of finding the best combination.
    Hope you are able to get everything resolved!
    Ben
    Welcome to the Forum!
    While I've never worked with a separation tank with a DE filter, take a look at this thread for info on using your DE filter.
  1. Troubleshooting inground cleaning system
    By str8deal in forum Pool Equipment & Operations
    Last Post: 08-25-2011, 07:48 PM
  2. Is an In-Floor Cleaning System worth the $
    By yukonjack3d in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-02-2011, 06:33 PM
  3. In ground cleaning system
    By joe1028 in forum Pool Equipment & Operations
    Last Post: 06-25-2011, 03:43 PM
  4. Cleaning my Hayward DE Filter - 1st time - Any tips?
    By wetshoes1 in forum Pool Equipment & Operations
    Last Post: 04-18-2007, 11:11 PM
  5. In floor Cleaning system with Intellichlor IC40
    By Katybug92 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-15-2006, 06:47 PM
