PoolDoc
The problem is not that the soda ash won't work if copper is present; the problem is that the soda ash will tend to change any metals present from a soluble (non-staining) to an insoluble (stains, colors, clouds) form.
If your pool's pH got really low, putting the Metal Free in is not necessarily a bad idea. It's essentially just a precaution, since really low pH tends to grab ANY metal it can find. Then, when you raise the pH, it drops it out all over your pool.
If you've got a vinyl liner pool with no exposed metals but stainless ladders and a titanium heat exchanger, my guess is you are good to go. Otherwise, if there is metal somewhere (mineral product, etc.) you might want to use the Metal Free and THEN run your pump 24/7 for the next 2 weeks, so that as the Metal Free breaks down, and the metals are released, they land on your filter rather than your pool walls.
BTW, I'd use a 1/2 dose of the Metal Free, and add more if there's any sign of discoloration.
Also, use 20 Mule Team borax rather than soda ash -- it's cheaper, less likely to cause problems with metals, and better for your pool. If your pH is way low, use 3 boxes per 10,000 gallons added SLOWLY to the skimmer with the skimmer basket in place and the pump running. Wait at least 2 hours and retest before adding more. Otherwise, 1 box every 10,000 gallons every 4 hours.
Finally, if you 'dump' a box in the pool's deep end, and watch for color change, if will give you some idea if metals may be present.
Ben
