Frustrated,Originally Posted by Very Frustrated
Looks like you have combined chlorine of 2.1. Keep adding the bleach, needs to be higher than 10, up around 20-25ppm to be effective.
Yours is a vinyl pool, right? The total hardness (calcium) is a bit high. It could be a contributing factor to the cloudiness. Once the combined chlorine is dealt with, then this needs to be addressed. Most advocate partial drain and fill, if fill water calcium is low. You may want to browse the "Dealing w/ Alk and Calcium" section.
PH and alkalinity look good. No worries there.
The TDS seems high, as mine is only in the hundreds. Calcium can factor into that value. Here's a recent thread: http://www.poolforum.com/pf2/showthr...ssolved+solids It, too, advocates a partial drain/fill to lower TDS. If so, fill water needs to be tested.
Keep adding the bleach to get the chlorine up, pump and filter 24/7 and have patience. It took awhile for the pool to get this way, will take a while to correct.
Good luck.
CaryB
