Thanks for the responses everyone. Now I'll know what to do if I ever really have that bacteria problem. Here's my latest tale of woe.
Thankfully, I realized what was going on the day after I last posted. I had my chlorine up to 22 and before I went to work the next morning I tested it again and it was holding strong. After work the chlorine was down to 9. Pretty fishy, huh?![]()
My pool was built in the fall and opened late last year. The pool store that my builder turned me over to told me everything I needed to do to get the pool going. That included dumping in a bunch of di-chlor to shock and tri-chlor for regular chlorination. After just a 2 or 3 weeks they were measuring my CYA level at 100. I now know that it's implausible for the CYA to rise that fast without specifically adding CYA to the water, but I had no idea at the time.
I have Ben's test kit now and the results I published earlier were based on my testing, with the exception of CYA. I've been getting comfortable with the kit but hadn't yet added the CYA test to my repertoire, so I relied on my old friends at the pool store (they measured 50). After I saw what was going on with the chlorine I did the CYA test myself and found no measurable CYA. I went to another pool store and they confirmed this (although they measured a PH of 8.0, when I knew it was really 7.4). I don't know why they are so off on their CYA test, but at least they're consistent!
I've added CYA. I thought that I could use the pool stores once in a while just to confirm my test results, but I'm done with them. From what I've seen, test strips are a pillar of accuracy compared to the pool store.
Lenny
