Hi ibmoore. Glad to see you back on the forum this year! I started a new thread for you instead of tacking on to the end of your thread from last year. I also merged your two posts and snipped the duplicated information. Hopefully, we can help you get going with this pool!
First of all, you are right that your pH is fine at 7.7. Just leave it alone. Your TA and hardness are fine, although I wouldn't suggest using any cal-hypo for your chlorine source this year.
We really need a CYA reading to be able to accurately help you. You can't assume that it is 0 just because none has been added this year. Sometimes pools keep their CYA over the winter, so you really don't want to add more until we know that reading. For now, go back and ask them to test CYA but don't let them talk you into buying anything.
You really need to get a good test kit so you don't have to rely on anyone else to test your water. Plus, homeowners who use the kit we recommend get more accurate readings than pool stores typically. The one we recommend is the Taylor K-2006 or 2006C (same kit, larger bottle of some reagents). If you buy it through the Amazon link in my signature, the Pool Forum makes a little money on the sale which helps us keep this form online. Only buy if the seller is Amato Industries, however. Some other sellers are substituting the K-2005 which you do NOT want.
For now, this is what I suggest you do:
-- Go to Walmart and get a cheap OTO/Phenol Red kit (yellow and red drops)
-- Every evening, add 1/2 gallon of plain, unscented 6% bleach slowly to the skimmer while the pump is running being careful not to splash yourself or the liner.
-- If the tester shows very dark yellow when you test, only add 1 quart instead of half gallon.
-- Run your pump 24/7 and backwash when the pressure rises 5-10 psi over clean filter pressure
-- If you are able, you can test chlorine in the morning as well. Same instructions. If really dark yellow, only add a quart. If not, add half a gallon.
Get your CYA reading and post it here and also tell us how the pool is looking and we'll go from there.
Get a kit, get a kit, get a kit! It will make your life much easier and it will make it easier for us to be able to help you.
