Results 1 to 4 of 4
Thread: Pool Alarm
    Jun 2011
    Mannford, OK
    Default Pool Alarm
    Does anyone know if you can use an inground pool alarm with an above ground pool?
    Default Re: Pool Alarm
    Hi boydcl,
    This is something that has not been discussed too much on the forum. Your best bet is to probably do a search. Go to our sister website www.poolsolutions.com and use the search feature there. You will probably have to log out to be able to see the threads. Hope you are able to find out some information to help.
    Welcome to the forum.
    Jun 2011
    Mannford, OK
    Thank you. Curious tho as to why you have to log out to see the threads? Thanks
    Long story -- has to do with using the "Getting Started" section as a gateway to separate real users from our daily flow of slimy spammers. Making the rest of the site invisible after the register 'breaks' the model they use to spam.
    Ben
