Closed Thread
Thread: hi 1st post
    tapevad Guest
    Default hi 1st post
    i am building a inground pool here in spain and need advice in next steps, i have built walls with concrete blocks with re-bars inside vertical and horizontal i have also built the steps (but have been told that they need ripping out )so that the base can be laid with concrete then re-bars before gunite is sprayed then construct steps is this necersery ?.
    Default Re: hi 1st post
    Please note: original poster is asking about pool building in Spain
    Hi Tape;
    I doubt anyone here can answer your question. Pool chemistry is universal, but pool chemicals are not, so it's often hard to answer pool chemistry questions from other countries: we don't know what's available.
    Pool construction is even worse. Codes (legal requirements), equipment, available contractor skills are ALL very different from what's available in the US -- not necessarily worse -- just different.
    This means that advice that might be perfectly good here, is bad advice for you, there in Spain.
    Sincerely,
    Ben
Closed Thread
  1. First post!
    By jeld44 in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-17-2012, 09:07 AM
  2. My First Post
    By jwhouse in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-16-2012, 04:01 PM
  3. First Post
    By stevetuck in forum General Interest
    Last Post: 06-02-2012, 01:39 PM
  4. My First Post
    By nKhona in forum In-Ground Pool Construction and Repair
    Last Post: 09-06-2011, 08:03 PM
  5. Not sure where to post this...
    By mbar in forum General Interest
    Last Post: 05-30-2007, 10:57 PM
