Results 1 to 8 of 8
Thread: IG Pool Liner Replacement Questions
    Default Re: IG Pool Liner Replacement Questions
    Welcome to the Forum!
    For his 'limited advice' Ben hit the nail on the head!
    For the rust, sand it down, clean the area and use Rustolium, or similar, spray paint to seal it.
    If the cracks in the floor are bothersome or are deep enough to let the liner into them, you can patch them with a THIN coat of hydrolic cement.
    I've got a LOT of experience with liner pools, feel free to 'pick my brain'
    Jun 2011
    Chicago, Illinois
    If the whitish deposit is probably zinc chloride from the galvanizing (zinc) on the steel, should I be looking to clean it up before installing the new liner ?. I will clean up the rust spots and treat. I am think of installing foam around the steel before installing the new liner, that will hopefully keep any rough surfaces from penetrating the new liner.
    Where can I purchase the hydrolic cement ?.
    JJNMRSDAD
    The wall foam is a great idea! If you need any tips on installing it, let me know.
    Lowes or Home Depot might have it, if not, try a masonry supply place.
    SalemCastles Guest
    You can get Hydraulic cement at any home hardware store.
    Jun 2011
    Chicago, Illinois
    How do I remove the Zinc Chloride ?
    If I leave the zinc chloride build up and install the foam wall liner, is the zinc chloride going to cause any future damage to the steel walls ?
