Results 1 to 8 of 8
Thread: IG Pool Liner Replacement Questions
    SalemCastles Guest
    Default Re: IG Pool Liner Replacement Questions
    You can get Hydraulic cement at any home hardware store.
    Jun 2011
    Chicago, Illinois
    How do I remove the Zinc Chloride ?
    If I leave the zinc chloride build up and install the foam wall liner, is the zinc chloride going to cause any future damage to the steel walls ?
