Thread: Is Polyquat essential?
    Lenny is offline Lifetime Member Thread Analyst Lenny 0
    Wilmington, Delaware
    Default Is Polyquat essential?
    Hi All,
    I'm a new pool owner. I learned a ton off of the old forum late last year but I'm still trying to get a handle on some things.
    One question I have is what some of the more experienced pool owners do about algae prevention. I did use Polyquat 60% prior to closing last year and I added some more when I took off the cover a couple of weeks ago. But the stuff is expensive.
    My feeling right now is that I'll just be dilligent about chlorine levels and try to skip the Polyquat. I'm sure many of you out there have tried it with and without Polyquat. What have you found?
    Thanks,
    Lenny
    Default
    I never use Polyquat except at closing. Never have. I am diligent about testing my water and maintaing an adequate chlorine level and never have any problems. It certainly doesn't hurt to use it, but as you said, it is another expense. If you take a couple of minutes a day to maintain good pool chemistry, you don't need it. More money in your pocket for something else. Just my opinion.
    Watermom
    Katy, TX
    Default
    Kinda depends where you live. (Hint: fill out your profile! ) Down here in Houston, TX, generally I start needing it when the water temps get into the high 80's and 90's. Even with keeping my CYA in the 40's, and keeping my Cl in the 4 range constantly (SWC) I still need it to fight mustard.
    Michael
    Default
    Thanks to you both.
    I'm in Wilmington, Delaware (added to profile ).
    I think I'll go without for now and see how things go later in the summer when the water gets very warm. Adding some for insurance while the water is warmer than normal would certainly be better (cheaper) than doing it for the whole season.
    I might even skip it at closing this year to see how that goes. If this year is any indication, I'll start champing at the bit to remove the cover around now so I should be able to get the chlorine level up before algae is a concern.
    Lenny
    duraleigh Guest
    Default
    Hi, Lenny,
    I have never used it. So far, so good (3 years)
    Dave S.
    Katy, TX
    Default
    Quote Originally Posted by Lenny
    Absolutely. Using it now is really not needed. I only use it when my normal methods don't keep the mustard down.
    Michael
    Default
    You don't need Polyquat for your normal pool maintenance. Diligent daily testing and correcting your water will work brilliantly.
    But, saying that, it DOES help if you let your FC drop due to sunshine, you take a trip and rely on someone else, etc. I like to add about an ounce and a half every week. That way, a 32 oz bottle goes for the whole summer. Since I watch for it to go on sale, and never pay more than $12 to $15/quart, I see it as cheap insurance. At closing, another quart and that's it for the season--$24-$30 more.
    Do be aware that after you add PolyQuat, you FC level will drop and you'll need to add chlorine a day or two after. It's especially pronounced when you add a whole quart at closing. At that time, I wait 48 hours (during which time the FC drops), then push my FC up to shock level (15ppm in my case) and close it.
    PolyQuat is insurance, no more, no less. You don't need it, but it doesn't hurt and CAN help.
  1. using Polyquat
    By Poolhouse in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-03-2012, 04:24 PM
  2. Polyquat or not ?
    By haze_1956 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-08-2007, 11:19 PM
  3. How to use Polyquat
    By CTIGuy in forum Dealing with Algae & Slime
    Last Post: 09-08-2007, 02:28 PM
  4. PolyQuat??
    By Sam_I_am in forum Dealing with Algae & Slime
    Last Post: 07-29-2007, 10:45 PM
  5. 40% Polyquat
    By jonv112 in forum The China Shop
    Last Post: 10-02-2006, 08:11 PM
